Restart the computer to run a hardware test
nwbts
2
Post by nwbts »
Im getting this message when adding a TPM protector
ACTIONS REQUIRED: 1. Restart the computer to run a hardware test. (Type: get-help Restart-Computer for command line instructions.)
What do I do next? How do I hardware test?
nwbts
2
Re: Restart the computer to run a hardware test
Post by nwbts »
Nevermind. I just rebooted and that fixed it
Yeap, agents can be finicky like that.
nwbts
2
Post by nwbts »
Thanks,
Why do some drives show status under protectors with TPM and value none and others show TPM protector with a masked value? I am pretty sure I selected just TPM protector for most of them.
We scan agents and have them return keyprotectors types installed and if it is a recovery password protector we import the recovery password.
If you add a pin or password using the plugin, then we also store that data with the agents key protector. We can not capture password or pin key protector data from agent for existing keys prior to plugin or if added out side plugin.
Post a screenshot so I can see what your seeing and I may be able to better describe that data.
