I am setting a package to install and update on the client level, but when I look at the individual computers, the update for the package isn't checked and the application isn't included in the update process.
when I initially add an application to install and update and check the computer. The application has both checked, at some point the updates check mark is removed.
how can I fix without going to each computer and enabling the update for each software?
Ilya
