Client Level Set for Install and Update/Computer level missing update
ilyak
Post by ilyak »
I am setting a package to install and update on the client level, but when I look at the individual computers, the update for the package isn't checked and the application isn't included in the update process.
when I initially add an application to install and update and check the computer. The application has both checked, at some point the updates check mark is removed.
how can I fix without going to each computer and enabling the update for each software?
Ilya
ilyak
Re: Client Level Set for Install and Update/Computer level missing update
Post by ilyak »
I had to run a sql query to fix this. Can this be fixed in the plugin?
Update will not check if install is not checked.
You should be able to uncheck install, recheck install then check update and it should reset all agents under that client.
