Backup Windows Reporting Emailer Script
This is a reporting Script that was requested.
This script will email 1 or more people a report of the entire MSP's enabled client base using Windows Backups plugin.
  • Unzip and Import XML into LabTech and look for script under the Maintenance subfolder
  • Schedule script against your LabTech server once a day
  • Edit line 2 in script adding in emails you want to send to
XML Zip file
P4L-BackupWindowsReporting.zip
(2.6 KiB) Downloaded 984 times
Also see word doc attached for more detailed instructions
Windows Backup Report Emailer.docx
(149.92 KiB) Downloaded 1008 times
