ESX health monitor not scanning on scheduled basis.
jtzabecki
Re: ESX health monitor not scanning on scheduled basis.
Post by jtzabecki »
Cubert wrote: Fri Apr 01, 2022 1:12 pm If you open the the main ESX Monitor link from the tools menu, Does it show valid?
Screenshot 2022-04-01 8.27.30 AM.png (114.47 KiB) Viewed 25646 times
jtzabecki
Post by jtzabecki »
Cubert wrote: Fri Apr 01, 2022 1:16 pm Also, just so we are on the same playing field.
What does your version say if you click the small squid icon in to of main window?
Screenshot 2022-04-01 8.29.51 AM.png (174.3 KiB) Viewed 25645 times
Ah ha....
Now we are getting some were... Ok thats the first thing to be fixed...
Version 4 used Python 27 which is now basically outdated. So in ESX plugin version 5 we updated the whole probe process to now deploy python 3.x which resolves a boat load of probe install issues we delt with as older python was depreciating.
So lets get you on 5.0
Im sending you a PM with the latest download link
jtzabecki
Post by jtzabecki »
Thank you so much. I have the new plugin installed. We will see if that fixes everything.
Make sure to restart the DBagent on Host. The plugin has some new items to load in.
Also you will need to redeploy all probes so they get new python builds.
jtzabecki
Post by jtzabecki »
what do you mean by redeploy all probes
All you need to do if anything is watch for probes to redeploy themselves to Python3.x If a probe seems to be stuck then all you should do is delete "any" c:\pythonXXX folders on that probe agent so it forces a reinstall of Python.
jtzabecki
Post by jtzabecki »
All appear to be back up and working, actually better then ever. Never got cable present on vga notifications. Those are nice.
It also now updates the discovery script regularly so that things like that are picked up so yes this version is improved.
