Sources
frankbe
Sources
Post by frankbe »
i run the scanner script - should there be the version number in the column available ?
and in the list of sources, should the button be green ?
Re: Sources
By default you do not need to apply a source to your Linux distros unless you want to add a 3rd party repo to capture a LOB application or such. But yes, grey is the color of icon.
As for the updates. obviously thats not right. We need to see what was returned from the agent during the scheduled script execution on agent.
Have a look at script and command logs during the timefram of a scheduled script scan and look at what it was returning. Post a copy of that here and I can see if there was some malformation. Open up the agent in the control center and review the script logs and command logs while script was running.
Scripts Log:
Screenshot 2025-02-27 125356.png (46.22 KiB) Viewed 11537 times
Commands Log
Screenshot 2025-02-27 125451.png (80.94 KiB) Viewed 11537 times
frankbe
Re: Sources
Post by frankbe »
i think i found the problem:
Your script depends on english for the default system language
We have german System and so output for german is for example :
apt-cache policy bash
bash:
Installiert: 5.2.15-2+b2
Installationskandidat: 5.2.15-2+b7
Versionstabelle:
5.2.15-2+b7 500
500 http://ftp.de.debian.org/debian bookworm/main amd64 Packages
*** 5.2.15-2+b2 100
100 /var/lib/dpkg/status
and in english:
bash:
Installed: 5.2.15-2+b2
Candidate: 5.2.15-2+b7
Version table:
5.2.15-2+b7 500
*** 5.2.15-2+b2 100
You look for the string "candidate"
Can you check your sripts and change the language to english maybe with
LANG=en_US_8859_1
Re: Sources
yes Let me look at this as well.
Re: Sources
In build 1.0.0.26 Due out today, I added to all scripts that create bash scripts for Linux or Mac to now include at the top
export LANG=en_US.UTF-8
export LC_ALL=en_US.UTF-8
