EDF APM-Enable Auto Updates - not being checked when the APM policy is applied.
leosq
1
Post by leosq »
I just created a new policy with the Auto Update option enabled and assigned to a location. Noticed that the agents haven't checked the EDF "APM-Enable Auto Updates" box after the policy being applied.
Screenshot 2024-12-11 125130.png (89.09 KiB) Viewed 18269 times
Screenshot 2024-12-11 125035.png (34.63 KiB) Viewed 18269 times
Re: EDF APM-Enable Auto Updates - not being checked when the APM policy is applied.
How di you apply this policy? By Client , By location or by agent? I need to know the control used to apply policy so I look in the right place fo a issue.
I am on the cusp of releasing the next build of this software that fixes another issue reported. If there is a problem, I can get the fix in on this build...
leosq
1
Post by leosq »
I have applied the policy by location.
Screenshot 2024-12-12 074320.png (23.29 KiB) Viewed 18224 times
We just posted build 1.0.0.24, we made a slight change to the enabler function for location and agent. The client enabler function had seemed to already had this change added to it. We suppect that this may be cauing your issue. We have tested in our limited environment but will look to hear back from you is this build has resolved your issue.
The build link is here
https://delivery.shopifyapps.com/-/710b ... f6fc9829f2
