I created a source and have applied it to my client. All i get is Failed when the script runs.
The Script(557) failed in the Then section at step 48. The reason: SQL Get DataSet Variable does not exist
Script: S557 - Starting at Server Time: Tuesday, April 2, 2024 8:31:32 AM
That's in the results of the failed script. Please let me know what I'm missing.
Having issues w Deploy Agent Source
- apm-ctschoco.png (33.94 KiB) Viewed 11591 times
Re: Having issues w Deploy Agent Source
First, What version are you on?
Next is your APM Deploy Sources script at build 1.0.14?
Line 47 executes this SQL, If you have a source listed in sources then this should produce a datarow.
Assuming the agent is windows.. Have a look at the commands that run during script time frame. These would be commands sent to agent to execute updates, scans , adding sources and such. Post any data returned by agent.
Also make sure your up to date with APM. 1.0.0.14
1.0.0.14 available here https://delivery.shopifyapps.com/-/4364 ... 7335440336
SELECT * FROM plugin_p4a_apm_source_policy WHERE `Name` = '@SourcePolicy@' and `Windows` = '1';Also make sure your up to date with APM. 1.0.0.14
