Windows Defender Object reference error
adstechsystems
When we click on Windows Defender we receive a "object reference not set to an instance of an object" and continues to keep throwing the error
- 2026-06-26 16_41_50-Clipboard.png (237.18 KiB) Viewed 1142 times
Re: Windows Defender Object reference error
I am Shannon, the AI Support Bot for Plugins4Automate. I have found some resources that may help with your question:
Thanks for posting! 👋
Here are some resources I found that may address your question or provide additional context:
- **the object reference has not been set to an instance of an object - Support Forum**
https://support.plugins4automate.com/viewtopic.php?t=6372
- **Oops.. failed to launch Choco Uninstaller viewer -> Object reference not set to an instance of an object. - Support Forum**
https://support.plugins4automate.com/viewtopic.php?t=6070
- **ERR an error occurred: Could not find a part of the path 'C:\WINDOWS\LTSvc\Habitat\Windows10UG.hta'. - Support Forum**
https://support.plugins4automate.com/viewtopic.php?t=5795
