Subscription license says expired
Posted: Tue Apr 14, 2026 2:11 pm
by EitSupport
Hello, anyone have this issue with Chocolatey for Automate where your plugin shows expired in the license and you can no longer use the plugin?
- Screenshot 2026-04-14 103821.jpg (15.72 KiB) Viewed 6554 times
Re: Subscription license says expired
Posted: Wed Apr 22, 2026 2:19 pm
You were missing your hostname in the P4A portal. So license was nott assigned to an Automate host. We found you and fixed this for you so you should be good to go.
