Subscription license says expired
EitSupport
Post by EitSupport »
Hello, anyone have this issue with Chocolatey for Automate where your plugin shows expired in the license and you can no longer use the plugin?
Screenshot 2026-04-14 103821.jpg (15.72 KiB) Viewed 6552 times
Re: Subscription license says expired
You were missing your hostname in the P4A portal. So license was nott assigned to an Automate host. We found you and fixed this for you so you should be good to go.
