Installed and completed install instructions. Still not IIS loaded.
WhizkidsTech
1
Post by WhizkidsTech »
I completed purchase and install on our hosted Automate environment.
I followed the install instructions. Restarted everything and it is coming up with DB Loaded, but not IIS Loaded.
How do I get the IIS to load.
Screenshot 2025-09-16 151546.png (17.89 KiB) Viewed 24048 times
Re: Installed and completed install instructions. Still not IIS loaded.
There is no IIS portion to plugin so you are good to go. You are seeing the correct items in your plugin manager. Make sure you restarted the DBagent at least once after plugin install so you get all the SQL tables and scripts auto created and you should be solid.
