Habitat Build 1.0.1.63 REleased
New released of Habitat build 1.0.1.63 which should auto update tonight.
Adds VMwear, Chocolatey and Defender services to Habitat Service Manager. I also updated the tabs created at the client ands location consoles for any Habitat service that is disabled.
So if you disable Windows Defender Service in Habitat then the tab for Windows Defender disapears. Enable the Service and tab will return. This goes for all sevices where a tab may be present. Should help declutter the Client and Location consoles from unused tabs.
Screenshot 2025-08-06 124737.png (177.21 KiB) Viewed 9728 times
dougan1978
1
Re: Habitat Build 1.0.1.63 REleased
Post by dougan1978 »
Would it be possible to have these new features start as turned off so we can turn them on if we want to use them. The Windows defender firewall thing turned firewall on for us on a few servers and caused some issues. Thank you!
