Refresh volume data
V-NET
1
Refresh volume data
Post by V-NET »
We installed just the other day. When I looked at BitLocker Manager for a client I know most of the PCs already had Bitlocker, I saw 0 agents or volumes using Bitlocker, and no golden padlocks. But when I expanded each agent I saw that the ones I expected to already showed protectors on the volumes, just not the golden padlock.
Clicking [Refresh Scans] did not change this. When I check the agents in Automate I can see the scripts ran. Right-click and [Refresh Volume Data] did get that volume a golden padlock and changed the count for Agents and Volumes.
Is this normal? Is there a way to do Refresh Volume Data for all agents in one pass? Will we need to manually scan PCs volumes this way?
adiadasman
Re: Refresh volume data
Post by adiadasman »
I installed the plugin yesterday and I am having the same symptoms. I thought that maybe I needed to let the scheduled scans run, but I can see in the agents I have checked that the scripts have run multiple times successfully, but I have no information on the main BitLocker Manager window or the volume list unless I refresh volume data manually on just one drive at a time.
The refresh button and the back end scanner runs the same scripts . The only difference is that the scanner schedules script on all Windows agents that are showing online where as the Rescan Button only schedules script on the client's agents that are online.
If you are seeing volume info and key info in the selected agents view then scripts have run. We can look at the scanner logs on the Automate host to see if there are any errors in scheduling scans and we can look at agent script logs to see if there is a error during a script run.
The drive status does not turn a drive to gold unless the drive returns ProtectionStatus = "On" for that volume during the script run. If drive status is anything but this, we show a unlock lock on drive.
The script runst the following PS script.
PS C:\WINDOWS\system32>
# Created for the Bitlocker plugin for Automate
# Author: Shannon Anderson
# Date: 10/18/2021
#Version 1.0.0.1
$Volumes = Get-BitLockerVolume
$i = 0
$ReturnData = ""
foreach($Volume in $Volumes){
     $VolumeType = $Volume.VolumeType
     $MountPoint = $Volume.MountPoint -replace ':',''
     $DriveSize = $Volume.CapacityGB
     $VolumeStatus = $Volume.VolumeStatus
     $EncryptionPercentage = $Volume.EncryptionPercentage
     $AutoUnlockEnabled = $Volume.AutoUnlockEnabled
     $ProtectionStatus = $Volume.ProtectionStatus
     if($i -eq 0){
          $ReturnData = "('%clientid%','%computerid%','$VolumeType','$MountPoint','$DriveSize','$VolumeStatus','$EncryptionPercentage','$AutoUnlockEnabled','$ProtectionStatus',NOW())"
         $i = 1
     }else{
        $ReturnData = $ReturnData + ",('%clientid%','%computerid%','$VolumeType','$MountPoint','$DriveSize','$VolumeStatus','$EncryptionPercentage','$AutoUnlockEnabled','$ProtectionStatus',NOW())"
Write-output $ReturnData
This is the return data:
('%clientid%','%computerid%','OperatingSystem','C','928.5508','FullyDecrypted','0','','Off',NOW())
In this case we are not encryped on this drive.
If you can query this table (plugin_p4a_bitlocker_volumes) if you see any incorrct volume lock colors for the computerID in question.
SELECT * FROM plugin_p4a_bitlocker_volumes Where computerID = '123';
See what the return of this data is?
See Protection Status column
Screenshot 2025-07-14 093140.png (7.27 KiB) Viewed 16713 times
Post back your findings..
V-NET
1
Post by V-NET »
Need instructions on how to query the table.
Launch the plugin and select the volume list button.
It will query table for that client ID and will return all volumes and all protectors assigned to volumes.
We released Build 1.0.0.20 today that has a typo fix and has added a extra scan function to better prep clients when plugin is installed or updated.
Get New Build Here
V-NET
1
Post by V-NET »
I got help running the query. Ran it against 2 agents that had the gold lock and 2 that did not. The two that did have the lock show protection status ON, the two that had a gray padlock do not appear, data not found. Only the ones that I ran [Refresh Volume] on show up in the volume list.
I will check out the new build.
V-NET
1
Post by V-NET »
The 1.0.0.20 update has fixed my problem. Thanks.
