If a Windows Server is pending a reboot and is rebooted, is it possible that the reboot flags are not cleared?
One of the biggest operational headaches is managing system reboots across multiple client environments without disrupting productivity. That’s where our latest project steps in—a ConnectWise Automate plugin designed to simplify reboot management while automating scheduling, enforcing dependencies, and reducing unnecessary downtime.
Yes, it’s possible—though not typical—for certain pending reboot flags on a Windows Domain Controller (or any Windows Server) to persist even after a reboot, especially if specific post-boot processes haven’t completed. In some cases, these flags may not clear until a user logs in interactively.
Here’s why that can happen:
- PendingFileRenameOperations in the registry (HKLM\SYSTEM\CurrentControlSet\Control\Session Manager) may not be processed correctly during boot if certain services or drivers don’t initialize fully until after login.
- Windows Update or CBS (Component-Based Servicing) flags might linger if updates were partially applied or if the system didn’t complete the update cycle properly.
- Group Policy or startup scripts that finalize update or reboot tasks may require a user session to trigger, especially if they're set to run in the user context.
This behavior has been observed particularly in Server 2022, where some users report that reboot-required flags remain even after multiple restarts—sometimes due to stuck registry keys or driver-related operations.
Server-2022-constantly-reports-a-pending-reboot
Shannon
Re: If a Windows Server is pending a reboot and is rebooted, is it possible that the reboot flags are not cleared?
Post by Shannon »
Thanks for posting! 👋
- **If a Windows Server is pending a reboot and is rebooted, is it possible that the reboot flags are not cleared? - Support Forum**
https://support.plugins4automate.com/viewtopic.php?t=6589
- **Project Report: Automated Reboot Manager for Group-Based Reboots - Support Forum**
https://support.plugins4automate.com/viewtopic.php?t=6572
- **EDF APM-Enable Auto Updates - not being checked when the APM policy is applied. - Support Forum**
https://support.plugins4automate.com/viewtopic.php?t=6516
Return to “Reboot Manager For ConnectWise Automate”
