Mass Install not working
frankbe
Post by frankbe »
i think, since the latest version, the mass install software does not work anymore.
When i chose a package with mass install the script "P4A Chocolatey Install Applications" is executed , there is no error, no log - but also no installed software
if i install the package in right-click->install software the software is installed without problems
Re: Mass Install not working
Yeap, There is a mistake at line 8 of the "P4A Chocolatey Install Applications" script. That "exit script" function should be disabled. Im fixing that now along with the other script issues we discussed.
