Chocolatey For Automate 3.7 - EDF Management tool
Agent EDF Management tool
The agent EDF management tool is an extention of the agent's EDF and provides you with quick access to their controls. EDFs are the primary method to control agent behaviors.
  • Chocolatey Approved- Enables or disables Application Management on agent.
  • Chocolatey Installed - Set by automation when Chocolatey is successfully installed.
  • Chocolatey Standard Deployment - Set by Automation when default repository is deployed.
  • Use WinGet - Turns on the WinGet functionality. You must also have Chocolatey Approved enabled.
  • Enable MSP License - (optional) Pushes the configured MSP license text file to selected agents.
  • Enable Extra Sources - This turns on source management and causes assigned sources to be applied.
  • Sources Enabled - Set by automation when sources assigned are successfully applied.
  • UNC Cache Enabled - Set by automation when UNC cache is verified.
  • Use UNC Cache - Turns on UNC Cache Management.
  • UNC Cache Master - Sets agent to manage the cache. making sure packages are up to date in cache.
  • Approved Applications Installed - Set by automation when the Auto Install function completes.
  • Auto Install Approved Applications - Turns on Auto Installs of Approved Applications.
Replicate any EDF to all agents at the client or location level.
The C control replicates the current agents setting to the entire client.
The L control replicates the current agent's settings to all agents at the selected agent's location.
