Daily Schedule - APM Policy
leosq
1
Post by leosq »
Hi there,
I just wanted to check if adding a daily schedule for new policies is part of the next updates.
I would be very handy..
Screenshot 2024-12-16 145331.png (51.79 KiB) Viewed 12898 times
Re: Daily Schedule - APM Policy
Applying no policy name to agent but enableing it for updates will update daily. Otherwise if a policy is assigned and update is enabled it will update based on policy. (weekly or Monthly).
So yes, It should do that now for you.
Screenshot 2024-12-16 124931.png (55.45 KiB) Viewed 12882 times
