Auto Install Approved Packages
To auto install approved applications for a given client you can select the checkbox to enable installs. Otherwise agents will auto update only packages already installed or manually installed.
This will flag all agent under this client to Auto install all enable approved applications. Disable applications will be skipped. This flag cause the agents to auto join the subgroup "Auto Install Approved Applications" and will only remain in this group until applications have been installed. Once applications installs have completed it will be noted and the agent will be removed from this group. It is normal for this group to remain empty for long periods.
