How to update your Credit Card for Plugin Subscriptions
How to manage your Credit Cards on Plugins4automate.com
Login to your account at https://www.plugins4automate.com/account/login
Once logged in you should see the following view with your plugins listed.
Select to Manage Subscriptions link, this should bring you to the next view.
Select the Payment Methods link.
You should see one or more payment methods listed. You can not modify these payment methods except for the name and addresses so if you are changing credit cards types or the numbers then you must add a new payment method.
If you want to just move subscriptions from one payment method to another and the other method is already listed you can skip the "add new method" and move on to assigning a subscription to a payment method.
For new Credit Cards Select Add Payment Method.
Enter your card information and save payment method.
Now find the new payment method in your list of payment methods and select to expand the payment method. There will be no associated subscriptions for the new payment method, so you will need to make that association by moving the subscriptions to the new payment method. Select the Move Subscriptions Here button.
Select the subscriptions you would like to move to this payment method and select the Move Subscription button.
You can safely leave the old methods listed in your payment methods or choose to remove them once no associations are made against the payment method. Expand the payment method and select the delete button to remove the payment method.
