MacOS Update Manager is not working
Chrisedv
Post by Chrisedv »
Hi There,
we try to Update one of our MacBooks with the Habitat MacOS Update Manager but nothing happens.
We saw that the Tool use the command "softwareupdate -i -a" and if we use this via CLI its working.
But nothing happens with the Manager.
As you can see in the Screenshot the Scan worked and the Tool show us that Updates are available.
But if we now try to force a Update nothing will happen
The Script get sceduled in CWA and the Status change to Running. But after after this it keeps Running and nothing happen on the Mac.
In the Logs we found this:
2022-07-22 11:09:00+02 MacBook-1 softwareupdated[246]: SoftwareUpdate: request for status for unknown product MSU_UPDATE_21G72_patch_12.5
2022-07-22 11:09:00+02 MacBook-1 SoftwareUpdateNotificationManager[732]: AssertionMgr: Cancel com.apple.softwareupdate.NotifyAgentAssertion-BadgingCountChanged assertion for pid 732, id 0x82D0
2022-07-22 11:09:00+02 MacBook-1 SoftwareUpdateNotificationManager[732]: SUOSUAuthenticationManager: Disabling local authentication requirement
2022-07-22 11:09:00+02 MacBook-1 softwareupdated[246]: Adding client SUUpdateServiceClient pid=732, uid=501, installAuth=NO rights=(), transactions=0 (/System/Library/PrivateFrameworks/SoftwareUpdate.framework/Versions/A/Resources/SoftwareUpdateNotificationManager.app/Contents/MacOS/SoftwareUpdateNotificationManager)
2022-07-22 11:09:00+02 MacBook-1 SoftwareUpdateNotificationManager[732]: AssertionMgr: Could not cancel com.apple.softwareupdate.NotifyAgentAssertion-BadgingCountChanged assertion - no assertion found for pid 732
2022-07-22 11:09:00+02 MacBook-1 SoftwareUpdateNotificationManager[732]: (null):softwareupdated: Service connection invalidated!
2022-07-22 11:09:00+02 MacBook-1 softwareupdated[246]: Removing client SUUpdateServiceClient pid=732, uid=501, installAuth=NO rights=(), transactions=0 (/System/Library/PrivateFrameworks/SoftwareUpdate.framework/Versions/A/Resources/SoftwareUpdateNotificationManager.app/Contents/MacOS/SoftwareUpdateNotificationManager)
Does someone have the same experience or can help us to fix it ?
Re: MacOS Update Manager is not working
So it sounds like the command is sent down to the console of the Mac, it started executing and returning data from the Mac, but the Mac either does not complete or from what you describe does not release and return after update processes complete or fail.
I'll have to go look at that and run some tests against my Mac to see if something in the IOS environment has changed since the design of that tool.
