Can't find the IP Block Config Tab
GThibeault
Post by GThibeault »
Sorry for this stupid question but I seem to be having a mind block on this one. I installed the IP Block Plugin but I can't seem to find where to configure it. I have seem the screen shot of the config tab but I can't seem to find that particular menu. Can anyone provide assistance. Thanks
Re: Can't find the IP Block Config Tab
Sorry for the late reply but this forum is down the list a bit.
This is an agent plugin so you will find this tool under the plugins view in the agents console when using the fat client.
Return to “IPBlock Country (region) IP Filter Plugin”
