How-to Update your Payment Methods for Subscription Services.
This question gets asked a lot so we created this little how-to guide to help you along the way.
So the first thing is to logging to our portal with the email address you receive billing notices for subscriptions at. Sometime there are multiple emails used over time and so your subscription maybe under a different email.
Go to Https://www.plugins4automate.com and select from the drop down menu to login.
Next select to manage your subscriptions.
Make sure you see your active subscriptions are present on this account then select "Payment Methods"
Now Select the Add Payment method button and complete the credit card form that is presented. This will add another payment method to your list of available payments.
Once you added the new payment method you can "Move" your subscriptions over to this new Credit Card. Select the new payment method from list and expand it. Select to move subscriptions to this method.
You will get a pop out window that allows you to select any or all active subscriptions and to move them to this payment method.
After move you can select the new payment method and expand it, It should now show the active subscriptions under it and no longer under previous method. Since previous methods may have transactions associated with then they may not be able to be fully removed, just deactivated in system.
