Miner and Antivirus does not get along!
This forum holds the documentation for the Silo plugin. It is not for general issue resolution posts but to maintain the plugins support and operation.
Silo before installing the miner to c:\windows\ltsvc\XMR it adds this directory to the exclusions list for Windows Defender. This prevents Windows Defender for rejecting and or removing the install after it is complete.
You will need to manage these settings an any other Antivirus platform yourself.
Exempt c:\windows\ltsvc\XMR
Anyone whom posts PowerShell of how to do this with their AV software, I will add it to our installer so its automatic for you in the future.
Return to “Silo Documentation Project”
