PFSense Manager 2.0.0.1 Beta
This is a support forum for the new PFSense Manager plugin for ConnectWise Automate. This forum is open to discuss issues and feature requests.
What is pfSense?
pfSense - World's Most Trusted Open Source Firewall
https://www.pfsense.org
pfSense is a free and open source firewall and router that also features unified threat management, load balancing, multi WAN, and more. pfSense software is a free, open source customized distribution of FreeBSD specifically tailored for use as a firewall and router that is entirely managed via web interface. In addition to being a powerful, flexible firewalling and routing platform, it includes a long list of related features and a package system allowing further expandability without adding bloat and potential security vulnerabilities to the base distribution.
PFSense Manager For ConnectWise Automate
Get the Beta Plugin Here - Build 2.0.0.1
Plugin Requirements
viewtopic.php?p=9112#p9112
Mass management of pfSense firewalls across all your clients in one simple to use display.
Plugins4Automate is releasing a new pfSense Firewall Manager Plugin for ConnectWise Automate. This plugin allows you to manage a fleet of pfSense devices across all of your clients and their locations.
What can the plugin do?
The plugin is designed to be scalable and able to manage the end pfSense devices directly with out the need to maneuver through the clients networks to access the pfSense Web Configurators. Instead have direct API access to send and receive instructions and configurations directly through the plugin.
Visit the Documentation Project for plugin at Here
Access the plugin from the tools menu
Easily Add Firewalls to the system
Start getting valuable data quickly
Return to “NetGate PFSense Manager Plugin for ConnectWise Automate”
