OS Types Tab
OS Types Tab
OS Types helps you keep count
The OS types tab is a set of charts and counters to assist you in defining your environment. You will find counters for the primary Windows desktop and secondary agents. A chart of Windows 10 deployments by version helps to understand where in the upgrade process is your environment and a chart for Windows Sever versions. To allow for a good scale we have added scrolling to this view so you can see the expanded views.
