Clients and Agents Tab (Global View)
This page is in Beta and subject to change
When you first select this tab you will be presented with a global view of the status of Patch Remedy. The counters and charts will show the overall status of all clients under management and being scanned by Patch Remedy.
Select a client from the list provided will display the Client version of the current statuses and provides control over the Client as a whole. Expand a client and select an agent under that client will display the agents statuses and provide controls to manage that agent.
