Offcie365ForAutomate User Class Permissions
This forum is used to document the operation and use of the office 365 for Automate plugin. Please keep comments to a minimum inside this forum. If you have a particular issue, post that issue in the main office365 forum.
As of 3.0.0.5, there are now user class permissions setup to allow access to the office 365 plugin.
If you are a Super Admin or have the Offcie365ForAutomate user class added to the users profile then you will see the Office365 For Automate Menu Item in the tools menu.
Otherwise you will not see this tool available.
Return to “Office365 For Automate Documentation Forum”
