Remove Chocolatey for Labtech
Moza
Post by Moza »
Hi Team,
What is the correct way to remove Chocolatey for Labtech from my Automate server?
I don't need it anymore and would like to know the best route to make sure nothing is left behind in the database etc.
Thanks,
Re: Remove Chocolatey for Labtech
Drop all tables that start with plugin_sw_chocolateyii_
This will remove all database items, next delete Chocolatey For LabTech Maintenance Service and Chocolatey For LabTech Installer scripts under the scripts/maintenance directory
Disable and then remove the plugin from plugin manager. Restart the DBagent to clear out plugin from memory.
That should pretty much do it.
Moza
Post by Moza »
Many thanks :)
