Google Drive API link
jallenEITP
Post by jallenEITP »
We have several ISO files on the Google drive that the "API Keyed URL" works fine but we uploaded a new file and the API Key URL says file not found for the new ISO. When we select the Keyless URL and test the file is there.
How do we fix the invalid Keyed URL?
BlooTech
Re: Google Drive API link
Post by BlooTech »
Did you make the file shareable? I had this issue and it was due to forgetting to share the new file. If its not shared it will state file not found in my experiences.
When logging in to Automate console it will cache the last credentials used to login to gdrive. Make sure that you are logged into the correct account in browser or clear cache and retry from plugin.
