Auto-Installer not working
aaroncampbell72
Post by aaroncampbell72 »
Initially, the auto-installer was working and then suddenly stopped. Error message in scripting log:
aaroncampbell72
Re: Auto-Installer not working
Additionally, here's the Installer Restuls:
The Script(6379) failed in the Then section at step 9. The reason: Kill command was issued.
Script: S6379 - Starting at Server Time: Wednesday, December 2, 2020 2:07:04 PM
IF F5 ValueOne (P1): APPCMD Comparer (P2): 3 ValueTwo (P3): T: 0.0155849
L1 F20 SetType(P1):1 Parameter(P2):0 VariableName(P3):TICKETING T: 0.0155849
L2 F172 SqlStatement (P1): 'Select count(ClientID) FROM plugin_sw_chocolateyii_client_config where ClientID = '55' and...' T: 0.0155849
L3 F20 SetType(P1):1 Parameter(P2):0 VariableName(P3):TICKETING T: 0.0311844
L4 F70 Value (P1): TICKETING Comparer (P2): 2 To (P3): 1 Jump (P4): :STARTTICKET T: 0.0321816
L5 F139 Note (P1): :CONTINUE T: 0.0321816
L6 F114 File (P1): 'C:\ProgramData\chocolatey\choc...' Check (P2): 0 Jump (P3): :PROGRAMDATA T: 0.0321816
Your going to need to post more info than this. The script log is not showing errors and is just an excerpt of the script running the ticketing section of the script.
There should be a complete log on the LTHost for the plugin along with logs in the console and on the agents console script and command logs.
We will need them all to move forward with an issue.
