Client Level Set for Install and Update/Computer level missing update
Posted: Mon Oct 26, 2020 11:44 pm
by ilyak
I am setting a package to install and update on the client level, but when I look at the individual computers, the update for the package isn't checked and the application isn't included in the update process.
when I initially add an application to install and update and check the computer. The application has both checked, at some point the updates check mark is removed.
how can I fix without going to each computer and enabling the update for each software?
Ilya
Re: Client Level Set for Install and Update/Computer level missing update
Posted: Sat Nov 07, 2020 8:48 pm
by ilyak
I had to run a sql query to fix this. Can this be fixed in the plugin?
Posted: Mon Nov 09, 2020 12:56 pm
Update will not check if install is not checked.
You should be able to uncheck install, recheck install then check update and it should reset all agents under that client.
