Mac Browsing History
Locked
DomoB90
Post by DomoB90 »
Hi there,
I needed to pull a report on a Mac computer but have just noticed it hasn't been logging the history. I checked the other Macs in our system and it would appear all Macs have not been logging surflog history. Is there something different we have to configure in the surflog plugin in order to allow the plugin to pull browsing history from Macs?
Best,
Dominick
DomoB90
Re: Mac Browsing History
Post by DomoB90 »
Just following up to see if there's been movement on this.
Surflog only supports Windows OS and does not run on MAC or Linux agents
I will look into what I can do for Mac. Looks like there are some promising shell scripts out there looking at safari history.. May be able to get something up and running.
Locked
