Private Browsing History/Microsoft Edge
Locked
DomoB90
Post by DomoB90 »
Hi there,
We just purchased this plugin and only just thought of these questions.
Does SurfLog pull from the browsing history for each browser or is the history logged somewhere else on the PC and then sent to Automate?
If the plugin is pulling only from the browsing history then that means we will not see browsing history when someone opens an InPrivate browsing tab, correct?
Does SurfLog log history from Microsoft Edge?
EDIT: I see now that Microsoft Edge history is tracked as well.
Thanks for the help!
Best,
Dominick
Re: Private Browsing History/Microsoft Edge
Correct the plugin queries the local agent for all history from popular browsers. There maybe limitations in "inPrivate" mode.
Locked
