Feature Request
MarkHodges
Feature Request
Post by MarkHodges »
I think a great feature request/selling option would be for the plugin to evaluate the list of applications available across all clients at install time and have it try and auto match as many of the apps with their corresponding chocolaty packages.
This way when someone has the plugin installed but not licensed, it basically will show them what they could be updating natively without any interaction at all if they wanted.
Then when they license the tool, they can easily turn off the apps they don't want to update individually for each client.
Re: Feature Request
We will be updating the App Search list as we grow so in essence you will get a expanding list of available matches which you can enable / disable as needed globally.
Allowing you to set search overrides at the client level is in the project plan as well.
Return to “App Genie”
