Security
CIIPres
Security
Post by CIIPres »
We have some "limited" techs that have access to a specific set of clients, but not all of them, and definitely not any global settings.
We want to give them access to the Powershell Command Console, but not access to any global settings (e.g., the ability to turn off Global Auto Upgrades, change the daily scanning interval, etc.).
How can we limit their access to the global settings, and still allow them to use the console?
Re: Security
Thats a good question? Not sure you can give them one without the other.
CIIPres
Re: Security
Post by CIIPres »
Is there a way to create override settings under the client settings so this could be turned off/on under the client?
