Moved or Migrated Labtech / Automate servers?
If you move or migrate servers or even if you do a internal "Forwarding Name" change then you will start to get license errors that host is not licensed.
This is because we use the Forwarding Name found in the LabTech DashBoard Configs as seen in the image below.
To update your account and get licenses back up and running you will need to update the host name we have on file with the name you have shown in the image above.
Update the name and save the name. Give it a few seconds and close any plugins you have open and reopen a plugin to see if the license issues are now gone. If for any reason it is not updating the licenses then send a email to support@plugins4automate.com and we will get you fixed up.
