PR Charts not working
I'm not certain if it's because i'm on a pilot release of Automate, but on version 1.0.3.85 of PR, none of the charts are showing up in the overview or the WUA Versions. I'm not certain, but I think that may be why my 'Systems reporting WUA is out of date' is listing all the machines that show in 'Systems Scanned'...
Any ideas?
Thanks,
James
Any ideas?
Thanks,
James
Re: PR Charts not working
Can you post a screen shot of the issues you are seeing?
Here you go. The overview screen. Also, i'm now on the release candidate v120.237
- 2017-11-21_PatchRem1.jpg (48.24 KiB) Viewed 22991 times
On the system you're using to open patch remedy, do a Whats my IP on that system and send that back to me. I will look up the chart logs to see what happened.
Shannon
Shannon
I emailed the two IP addresses to you via the forum. It happens on my laptop at home (or wherever I am) and my office desktop as well.
Thanks,
James
Thanks,
James
didn't get IP addresses,
Email me at support@ plugins 4 automate . com
Ok, I emailed them to that address...
I haven't heard back from our offline email thread. Any news or next steps for troubleshooting?
Also, I think the date/time is off on the server. These posts are showing a June date and it's November...
Date? Are you referring to your join date?
I do not believe I received the email. Can you resend it? Also cc helpdesk@ which should create a ticket for us.
Nope, i'm talking about posts to the thread...
- 2017-11-30_10-07-27.png (132.92 KiB) Viewed 22905 times
