Build 1.0.3.20
Build 1.0.3.20
https://delivery.shopifyapps.com/-/e821 ... 135d0d76f3
---build 1.0.3.17---
Added feature for single selective scan intervals per day. You can override the multiple scan cycles and set to scan at any hour once a day.
---Build 1.0.3.20---
Updated script to now look for insession backups and to quit if backups are running (preventing a backup failure do to scan)
Added new Feature VSS Shadow storage and the ability to reallocate Shadow storage.
Added new Remove Job Button on computer console, This removes any active backup jobs.
Removed the function that disables backup jobs from the Enable/Disable button. Enable disable now only tests that backups can run but does not stop or remove backups.
