Build 1.0.3.78
Build 1.0.3.78
Added KB4025337 July 11,2017 Security Rollup For Windows 7 and 2008R2
Fixed display around the Patch Percentages view, fixing scroll bar view
Fixed Export of WUA Versions to Excel removing the extra LineFeeds in the export causing it to distort.
Added Console view to Disable Win 10 Updates view
Updated the Enable and Disable feature in Win 10 Updates Deferred view so it now instantly updates the view.
https://delivery.shopifyapps.com/-/be3d ... fb832482cb
bcockrell
Re: Build 1.0.3.78
Post by bcockrell »
We are seeing that KB4025337 is causing Windows 7 machines to freeze and causing BSOD. Is Patch Remedy pushing this update out on it's own? How do we prevent patch remedy from pushing this out?
Re: Build 1.0.3.78
It is, you can disable this by going into the Patch Remedy Maintenance Script and disable this line to stop it from doing that update.
