PowerShell Consoles fails to load corectly.
Posted: Mon Apr 10, 2017 12:29 pm
There may be times when a Tech's PS console fails to load correctly after installing and verifying modules were installed. The problem is that modules were only installed to the 32 bit side and not the 64 bit side and the Tech's system is a 64 bit system.
The Error!!!
Here is how to fix.
When the modules verify is run it should place mods in the correct folders if it sees 64 bit systems. Sometimes this does not happen for one or more reasons.
If after running verify modules you still do not work correctly then run the following commands at the commandline.
xcopy C:\Windows\System32\WindowsPowerShell\v1.0\Modules\MSOnline C:\Windows\SysWOW64\WindowsPowerShell\v1.0\Modules\MSOnline\ /i /s /e /h
and
xcopy C:\Windows\System32\WindowsPowerShell\v1.0\Modules\MSOnlineExtended C:\Windows\SysWOW64\WindowsPowerShell\v1.0\Modules\MSOnlineExtended\ /i /s /e /h
Verify that the 2 folders exist in the syswow64\windowspowershell directory
Relaunch your consoles and all should now work as expected.
