Patch Success Tab not updating
ben_
Post by ben_ »
Hey Cubert,
I have been running the plugin for just over a month now and the Patch Success has not one populated with any data. Am I doing something wrong?
Also, Feature request: Allow me to set a EDF in the client LOCATION to add it to the scan list. That way I dont have to remember to goto the plugin to add the check box. I also have clients that have managed and unmanaged locations.
Re: Patch Success Tab not updating
What version of LabTech are you on?
And what patch engine are you using? (LT10.5 on LT11 or LT11) There is a flag that sets pre LT11 patching for LT 11 servers. What is the status of this check box?
ben_
Post by ben_ »
Sorry forgot I asked this question a while back.
I just updated to 1.0.3.48
On Labtech v11.0.349
The 'Use Pre LT 11 Patching' is unchecked
You are using the native patching of LT11 and "not" still on LT 10.5 patch schema? If so then not having the box checked is correct.
Here is the sql query for the stats for LT11 Native patching, copy and paste into sqlyog and lets see what it says.
SELECT c.computerid as ID,IF(c.LastContact > date_add(now(),interval -5 minute),'Yes','No') As `Online`,c.NAME AS Name,l.NAME AS Location,b.NAME AS Client,IFNULL(s1.installed, 0) AS installed,IFNULL(s2.missing, 0) AS missing ,IFNULL(s3.total, 0) AS total ,IFNULL(s1.installed / s3.total * 100, 0) AS percent_installed, c.OS FROM computers c JOIN clients b ON  c.clientid = b.clientid JOIN locations l ON c.locationid = l.locationid LEFT JOIN (SELECT COUNT(hotfix.computerid) AS installed,hotfix.computerid FROM hotfix WHERE hotfix.approved = 2 AND hotfix.installed = 1 GROUP BY hotfix.computerid) AS s1 ON c.computerid = s1.computerid LEFT JOIN (SELECT COUNT(hotfix.computerid) AS missing,hotfix.computerid FROM hotfix WHERE hotfix.approved = 2 AND hotfix.installed = 0 GROUP BY hotfix.computerid ) AS s2 ON c.computerid = s2.computerid LEFT JOIN (SELECT COUNT(hotfix.computerid) AS total,hotfix.computerid FROM hotfix WHERE hotfix.approved = 2 GROUP BY hotfix.computerid) AS s3 ON c.computerid = s3.computerid Where b.ClientID IN (Select ClientID FROM `plugin_sw_patch_remedy_config` Where MasterSwitch = 1) AND c.ComputerID NOT IN (SELECT ComputerID FROM `plugin_sw_patch_remedy_client_exclude`) and c.OS LIKE '%windows%'  HAVING 1  ORDER BY `Client` DESC LIMIT 0,5000
