Build 1.0.3.41 is now available at the following URL
https://delivery.shopifyapps.com/-/8b1a ... 8b7ac293d9
::Build Notes::
---1.0.3.41---
Added New Tab "Win10 Defer Upgrades" which displays all the Windows 10 systems under Patch Remedy maintenance and if they are enabled or disabled.
Added Scanner feature to collect Windows 10 Defer Upgrade option
Added Feature to allow you to enable or disable the Defer Upgrade option on any Windows 10 system that supports it.
Adjusted default font size for tab window and enlarged PR window by 30 px
Release Build 1.0.3.41
Jump to
- ↳ Scripts
- ↳ Automate Package Manager
- ↳ Documentation
- ↳ Chocolatey Plugins
- ↳ App Genie
- ↳ Chocolatey For Labtech
- ↳ Chocolatey For Automate
- ↳ Habitat
- ↳ BitLocker for Automate
- ↳ Patch Remedy 5
- ↳ Documentation Project
- ↳ SurfLog for Automate
- ↳ Office365 For Automate
- ↳ Office365 for LabTech
- ↳ Defender For Automate
- ↳ Defender Documentation
- ↳ Active Directory UC
- ↳ Silo For Automate
- ↳ Cleaner For LabTech
- ↳ Printer Status Plugin
- ↳ Linux Update Manager
- ↳ Magma For LabTech
- ↳ Nagios for LabTech
- ↳ Map Drives Plugin
- ↳ Agent Status Plugin
- ↳ Flue Shot AV Plugin
- ↳ Net Detective plugin
- ↳ SQL Query Analyzer plugin
- ↳ PFSense 4 LabTech
