Feature request
Posted: Mon Dec 05, 2016 4:48 pm
by efiniste
Is it feasible to add a control for deferring upgrades on Windows 10 machines?
I currently do this via a repeating regedit script but it would be neater to include it with the rest of the patching controls within Patch Remedy.
Cheers,
Steve
Re: Feature request
Posted: Thu Dec 08, 2016 5:44 pm
No problem, Hows this for a start?
Patch Remedy Version 1.0.3.41 now has a scanner for Defer Windows 10 Upgrades. And we allow you to reset the option from the plugin.
- Win10DeferUpgrade-tab.PNG (112.25 KiB) Viewed 15160 times
Re: Feature request
Posted: Wed Dec 14, 2016 5:56 pm
by efiniste
Thanks Shannon. Installed the update a couple of days ago but my system count is still zero on that tab. I've tried doing a force scan but nothing changed. The rest of Patch Remedy looks to be working fine.
Steve
Re: Feature request
Posted: Wed Dec 14, 2016 7:58 pm
did you restart the DBagent? a new DB table is needed to store this information so you need to make sure that LabTech has created it.
Re: Feature request
Posted: Wed Dec 14, 2016 8:00 pm
Also you must launch Patch Remedy once so it replaces the scanner script then allow it to scan once before data shows. Check the scanner script version. Does it match the build #?
Re: Feature request
Posted: Thu Dec 15, 2016 2:14 pm
by efiniste
Thanks. DB agent restart sorted it.
