Feature request
efiniste
Feature request
Post by efiniste »
Is it feasible to add a control for deferring upgrades on Windows 10 machines?
I currently do this via a repeating regedit script but it would be neater to include it with the rest of the patching controls within Patch Remedy.
Cheers,
Steve
Re: Feature request
No problem, Hows this for a start?
Patch Remedy Version 1.0.3.41 now has a scanner for Defer Windows 10 Upgrades. And we allow you to reset the option from the plugin.
efiniste
Re: Feature request
Post by efiniste »
Thanks Shannon. Installed the update a couple of days ago but my system count is still zero on that tab. I've tried doing a force scan but nothing changed. The rest of Patch Remedy looks to be working fine.
Steve
Re: Feature request
did you restart the DBagent? a new DB table is needed to store this information so you need to make sure that LabTech has created it.
Re: Feature request
Also you must launch Patch Remedy once so it replaces the scanner script then allow it to scan once before data shows. Check the scanner script version. Does it match the build #?
efiniste
Re: Feature request
Post by efiniste »
Thanks. DB agent restart sorted it.
