Powershell Console not working, big red errors
If you are seeing Module errors when launching Powershell consoles from our plugin then have a peek at our video at https://youtu.be/cNzR__QoM0U
As of build 2.0.0.57 the module installer accounts for 64 bit module loads and adjusts accordingly.
Re: Powershell Console not working, big red errors
If you have upgraded from 2.0.0.55 then you will want to verify modules again on workstation before using shell.
This will cause the modules to be copied over to the c:\windows\syswow64\windowspowershell\1.0\modules directory as well as the default directories so that the new shell will work correctly after update.
