Release Build 1.0.3.02 now available
We have started to progression of Patch Remedy to LT 11 and with that this is our first build that looks at LT version and changes as version changes.
We also been a little busy working on these updates as well...
We should now be loading 2500 agents worth of data in under 30 seconds. Major updates in speed have been added to Patch Remedy
---1.0.3.02 ---
Updated Export tools from form buttons to images
Updated WUA Versions Export to now include new column "is up to date" to point out which systems are out of date
Updated queries for WUA Out of date to also match OS type to each PC that is compaired to MAXWUA list.
Updated The query used to build WUA UpToDate percentage guage to follow same verbage as the WUA out of date list.
Started LT 11 Version support with updating queries to support LT 11 patch manager version.
Increased default data view sizes from 50 to 250
Turned off Java script errors notifications on charts
Updated [Patch Success] -> Systems that have successfully installed patching from 1 day to last 7 days
Added (s) to text around places where "System" needed to be "Systems"
Enjoy
Cubert :ugeek:
jbrantley
Re: Release Build 1.0.3.02 now available
Post by jbrantley »
Thanks Cubert. Not sure if it is just me, but when I click to view records greater than the 250, it reverts back to only 50 records at a time.
AJB703
Post by AJB703 »
jbrantley wrote:Thanks Cubert. Not sure if it is just me, but when I click to view records greater than the 250, it reverts back to only 50 records at a time.
Confirmed. My first pagination will increment 250 records, any subsequent pagination forward/backward is 50 records.
Roger that I will have a fix out shortly, (Monday)
