Adobe Update with Pro Installed
vkent39
Post by vkent39 »
Does anyone have a good process or solution they use when the machines have Adobe Pro installed. I am sure most people have experienced that is reader does an update from Chocolatey it sets reader back as the default instead of Pro. Short of running a report of all the Pro installations and manually excluding them we are just curious if anyone has come up with a better solution?
benf
Re: Adobe Update with Pro Installed
Post by benf »
No, thats what we did , and moving forward if the client purchases Adobe from us we go and set it back on the individual client.
