Page 2 of 2
Re: ESX health monitor not scanning on scheduled basis.
Posted: Fri Apr 01, 2022 1:29 pm
by jtzabecki
Cubert wrote: Fri Apr 01, 2022 1:12 pm If you open the the main ESX Monitor link from the tools menu, Does it show valid?
Screenshot 2022-04-01 8.27.30 AM.png (114.47 KiB) Viewed 25740 times
Posted: Fri Apr 01, 2022 1:30 pm
by jtzabecki
Cubert wrote: Fri Apr 01, 2022 1:16 pm Also, just so we are on the same playing field.
What does your version say if you click the small squid icon in to of main window?
Screenshot 2022-04-01 8.29.51 AM.png (174.3 KiB) Viewed 25739 times
Posted: Fri Apr 01, 2022 1:49 pm
Ah ha....
Now we are getting some were... Ok thats the first thing to be fixed...
Version 4 used Python 27 which is now basically outdated. So in ESX plugin version 5 we updated the whole probe process to now deploy python 3.x which resolves a boat load of probe install issues we delt with as older python was depreciating.
So lets get you on 5.0
Im sending you a PM with the latest download link
Posted: Fri Apr 01, 2022 1:59 pm
by jtzabecki
Thank you so much. I have the new plugin installed. We will see if that fixes everything.
Posted: Fri Apr 01, 2022 2:11 pm
Make sure to restart the DBagent on Host. The plugin has some new items to load in.
Also you will need to redeploy all probes so they get new python builds.
Posted: Fri Apr 01, 2022 3:16 pm
by jtzabecki
what do you mean by redeploy all probes
Posted: Fri Apr 01, 2022 6:48 pm
All you need to do if anything is watch for probes to redeploy themselves to Python3.x If a probe seems to be stuck then all you should do is delete "any" c:\pythonXXX folders on that probe agent so it forces a reinstall of Python.
Posted: Fri Apr 01, 2022 6:50 pm
by jtzabecki
All appear to be back up and working, actually better then ever. Never got cable present on vga notifications. Those are nice.
Posted: Mon Apr 04, 2022 12:43 pm
It also now updates the discovery script regularly so that things like that are picked up so yes this version is improved.
