MyCMD Options.
NathanWilson
MyCMD Options.
Post by NathanWilson »
I'm trying to embed patch remedy into a multi function script.
I've got the scan working where mycmd = scan in the script properties.
However can anyone advise the other flags? i.e. firmware only, and/or upgrade and update?
NathanWilson
Re: MyCMD Options.
Tried reviewing the command parameters but appears these encrypt so can't reverse engineer
NathanWilson
Re: MyCMD Options.
Found them! Placing here if anyone else is looking:
Scan = SCAN
Update= UPDATEALL
Upgrade W10 to latest = UPGRADEWIN10
Upgrade W10 to W11 - UPGRADEWIN11
Return to “Patch Remedy 5”
